Fuel Pumps
Old Jul 31, 2013 | 12:29 PM
JBood's Avatar
JBood is on a distinguished road
Default Fuel Pumps
So i initially purchased this model
on ebay for $66 shipped. It was DOA. Could hear the pump run, and the gauge worked but no fuel. All lines are new, new tank seal and lock ring, new quick connectors etc.. I primed it many times and cranked a bit too. Unhooked the filter and no fuel in the feed. I don't recommend buying from am-autoparts despite their high positive feedback and high sales volume. I asked them a few questions about the pump, post-purchase and they didn't respond to my questions regarding the pump not working, though they are issuing a full refund.
I ordered a http://www.ebay.com/itm/380536340966?ssPageName=STRK:MEWNX:IT&_trksid=p398 4.m1439.l2649"]Redline by Herko with a 1 year warranty for $72 shipped. Anybody have any experience with this unit?
Old Jul 31, 2013 | 03:08 PM
Habu's Avatar
Habu is on a distinguished road
Not this particular model, but the 4-door equivalent. It was a hassle-free purchase, the company delivered on-time and the thing actually worked. It was installed a few months ago, and so far has worked fine.
It was a temporary fix, while I was deciding if I wanted to keep the Blazer (or sell it as a running vehicle). The plan is to eventually replace it with OEM.
The way such plans tend to go for me, that will get done shortly after this pump dies.
Old Jul 31, 2013 | 03:13 PM
JBood's Avatar
Default ...
Habu,
I hope you're referring to the Herko unit, yes? I don't see how you can go wrong with the same warranty as an AC/Delco or any other big name manufacturer. Does anybody make a lifetime warranty pump? Or have any experience with a "high-flow" on ebay like this?
Attached Thumbnails Fuel Pumps-%24t2ec16hhjfoe9nh6qtppbro-6ymbq-%7E%7E60_57.jpg
Old Jul 31, 2013 | 03:45 PM
JBood's Avatar
I had to cut out the factory pigtail (4pin square) for the junk pump (4 pin rectangle)...looks like the Herko will use the OEM version so I getta splice that back in...*lame*. We shall see, updates once it arrives.
Old Aug 1, 2013 | 05:43 AM
Habu's Avatar
I apologize for not being more clear. I am running the Herko pump.
Given the lower price of the Herko pump, I'm just a bit hesitant about trusting it completely. It may last forever, but I want to be prepared to replace it if necessary.
Old Aug 1, 2013 | 09:48 AM
JBood's Avatar
Default Herko Pump
I understand completely.. did it come with a different style pigtail you had to splice into the factory harness? Or did stock plug right in... Chomping at the bit waiting on this second pump.. I had a bad fuel leak due to rust right over the rear axle/top shock mount so I replaced the feed and return lines, figured I may as well put in a pump while i had the tank off.
Old Aug 2, 2013 | 03:13 AM
Habu's Avatar
I think it just plugged in (I had someone else install it). I didn't have time to do it the way I wanted to (cut a new door over the pump), or the patience to do it the book way.
Old Aug 2, 2013 | 03:29 AM
Thogert's Avatar
You guys may have a good warranty, but you can expect to be replacing it soon. These trucks NEED acdelco or delphi pumps. There are more than just a few here that have skimped out on a pump and ended up replacing it more than once.
Old Aug 2, 2013 | 07:54 AM
chris015's Avatar
^^^^ x over 9000
Old Aug 9, 2013 | 05:20 PM
JBood's Avatar
mine is working great... very quiet pump. Exhaust is on, runs and sounds great!
