Fuses and Relay mounted in pass. fender???
Old Nov 27, 2013 | 08:35 PM
metalmeltr's Avatar
metalmeltr is on a distinguished road
Default Fuses and Relay mounted in pass. fender???
What do these control? I just found then today playing around. I fund that the 30 amp maxi fuse is blown and i don't know what it controls.
Cover over fuses
Loose wire connects to fuse under battery tray, runs to relay
Attached Thumbnails Fuses and Relay mounted in pass. fender???-dscf2438.jpg   Fuses and Relay mounted in pass. fender???-dscf2439.jpg   Fuses and Relay mounted in pass. fender???-dscf2441.jpg
Old Nov 27, 2013 | 08:53 PM
richphotos's Avatar
Year make model?
Old Nov 27, 2013 | 09:24 PM
metalmeltr's Avatar
2001 Chevy blazer, sorry about that.
Old Nov 27, 2013 | 11:40 PM
richphotos's Avatar
its all good, thanks, I am good on first gens, second gen people will come to help. I am not sure what that is for... What is the number that is listed under the "delphi" on there?
I know delphi as fuel pumps and injectors. Other than that... I am clueless.
We will figure this out LOL.....
Is there anything you have tried to use but has not worked? I am just trying to think of that 30amp fuse that is blown.
Old Nov 28, 2013 | 12:22 AM
metalmeltr's Avatar
PA66 is the number. Delphi made all sorts of electronics for these trucks, I have not found anything that isn't working. I just randomly found it. I saw the assembly and took it out to see what it was and found the blown fuse.
Old Nov 28, 2013 | 03:42 PM
metalmeltr's Avatar
Well a little detective work with the wiring and a few searches has revealed that the relay and fuse controls the AIR pump. the relay controls the pump turning on, the 30 amp fuse is the pump power, the 10 amp fuse controls the vacuum solenoid mounted next to the AIR pump.
Old Dec 1, 2013 | 03:12 AM
specialty8's Avatar
specialty8 is on a distinguished road
Good work. What's the verdict? Did you replace the fuse and find any noticeable difference or anything?
Old Dec 1, 2013 | 01:21 PM
metalmeltr's Avatar
I have not yet replaced the fuse. That will happen sometime next week. It is strange that considering the air pump must not be working that I do not have a check engine light showing up.
dimone545
Nov 17, 2015 06:56 PM
spiritscense
May 29, 2012 11:04 PM
nineteensixtycaddy
Sep 12, 2010 08:54 PM
DrEaMsTeVe
Apr 25, 2009 02:52 PM
bestes
May 31, 2008 03:16 PM
