Gas Meter not accurate
Old Nov 10, 2008 | 12:22 PM
MacK's Avatar
MacK is an unknown quantity at this point
Default Gas Meter not accurate
I have a 99 blazer and i just want to know which is more accurate, the analog meter on the dash or the digital reading on the module on the roof. Because when i get the low gas light the analog points to empty but the digital readout still says i have like 150km left. I just want to know because in the summer i was getting around 425km for a full tank of gas but now i'm get 320km soabout a100km less.
Old Nov 10, 2008 | 12:24 PM
Default RE: Gas Meter not accurate
How much fuel are you putting in when you are on E on the dash gauge?
Old Nov 10, 2008 | 12:39 PM
MacK's Avatar
usually varies, usually around48 - 51 litres but yesturday idrove until thedigital readout said only 90km left and it wentup to 55 Litres.how many litresdo you normally get on empty?
Old Nov 10, 2008 | 12:52 PM
rriddle3's Avatar
My 'low fuel' light comes on when I have 3-4 gallons left in the tank. That gives me ~60-80 miles of driving left.
Old Nov 10, 2008 | 01:08 PM
WolfPack's Avatar
I wish I had a gas guage [&o]
On a related note, if the fuel sender dies, will the overhead console give the correct range? I would think so, since the sender just supplies a level to the guage, not a quantitative volume of fuel used. Is that right?
Old Nov 10, 2008 | 01:24 PM
The console works off of an algorithm based on the average miles per gallon and the distance traveled, knowing the capacity of the tank. The problem with that is if you are driving more aggressively or less aggressively, your actual mileage may be very different from your average (depending on when you last reset it).
Old Nov 10, 2008 | 01:42 PM
MacK's Avatar
How do you reset the overhead thing? and if my dash meter is correct on the low fuel is there any reason i would be losing about 100km of gas? I don't drive very hard, i change my oil about every 8,000 km with mobil 1 high mileage synthetic, i have a k n N drop in filter and i put a new cat the only thing bad on my truck is my tires, there pretty bald.
Old Nov 10, 2008 | 02:44 PM
rriddle3's Avatar
ORIGINAL: MacK
How do you reset the overhead thing?...
Switch the readout to one of the 'average' readings (average speed, average mileage, etc.), hold down both left hand buttons at once until the reading resets. Done.
Old Nov 10, 2008 | 04:09 PM
MacK's Avatar
ok cool thanks, last question does anyone know how many litres a 99 4x4 blazer can hold for gas? i heard it holds 18 gallons so that's about 68 litres i think but i want to know if that's true or not.
Old Nov 10, 2008 | 05:57 PM
rriddle3's Avatar
2 door = 19 gallons
4 door = 18 gallons
J.R. Clay
Mar 7, 2011 08:03 AM
Jisher
May 6, 2010 07:38 AM
drperry
Mar 9, 2007 09:57 PM
dropd4door
Feb 21, 2006 11:43 AM
