Gas tank overflow leak after filling the tank normal?
Old Nov 13, 2013 | 12:20 AM
Smc's Avatar
Smc
Smc is on a distinguished road
Default Gas tank overflow leak after filling the tank normal?
I am new to the blazer world I just got a 2000 blazer white and I went and filled the tank and topped it off a couple time past the first pump shut off so then gas poured out the top of my tank for a like 30 sec and stopped is this normal? Or do you guys know why it happened?
Old Nov 13, 2013 | 12:34 AM
richphotos's Avatar
umm... sounds like you over filled it.
Where did the fuel come out? the filler neck where you put the nozzle?
If so.. you over filled it. It does this to every car when you over fill.
Old Nov 13, 2013 | 09:29 AM
Smc's Avatar
Smc
no it didn't come out if the neck it came from the top of the tank i think from where the fuel lines run it was dark couldn't really see.exactly. a couple. people have talked about a evap system dowb there it could have came out if but idk I'm new to thus truck
Old Nov 14, 2013 | 04:46 PM
odat's Avatar
Talking
No leakage is not normal - Look for a hole in tank - rust spot ect. - unhooked lines or bad lines / vapor return, fuel return, vent line or the O ring under the sending unit/fuel pump - u might want too add this too your ride - i think it's a good idea too have one even with no leaks
01xtreme_chevy
Feb 19, 2014 03:14 PM
phxjosh
39
Nov 7, 2013 12:41 PM
adella1221
Nov 5, 2010 05:59 PM
megaroos_00
Jul 23, 2010 02:22 PM
98chevblazer2004
Nov 11, 2009 05:50 PM
