Headlight question
I bought myself black headlights off ebay and now I am worried I may have bought the wrong ones.
http://images.channeladvisor.com/Sel...HS1098JMYD.jpg What is that wire coming out of the back middle? I have a 2000 2dr 4x4 and that wasnt there when I took my old ones off. |
RE: Headlight question
It looks like these headlamps use a differenet style low beam bulb. It should still plug in just like your current headlights do as the plug on the end of those wires looks like it is the same as the stock bulbs.
Ok thanks I would rather buy a bulb then going through the hassle of trying to return these.
The ones with the thing on the back are projectors, but the actual headlights above has no projectors
So they just screwed up the pictures...?
Either projector style, or non-projector style will work. As I stated earlier, the projector styled headlamps have the factory bulb plug on the end of the wires for a plug-n-play installation. If your's don't have the projector, then you should just simply have to swap the bulbs over and hook up the wiring. If they do have the projectors, then you only have to swap over the high beam and park/signal light bulbs, then plug in the wiring and go.
ok I understand now thanks for the help!
post pics up when youre done! ive got those same lights on my christmas list...
My blazer is at the dealership getting parts painted, Ill get the lights installed probably thurs-friday then ill post the pics up. I also have black tailights for the blacked out theme.
Next on my list is wheels. |
There is the headlights installed for anyone who wants to see what they look like.
Very nice! Where in NY do you live?
Buffalo
Looks good! Will have to invest in some down the road.
old thread but my projectors came with a base for a 9005, not an h1 or h3. i cant see usin an h1 4 a headlight even thru a projector.
i have hid so i dont even use the 9005 |
I have H1 bulbs in mine. Work great.
loooks good. i like the blackout theme you are going for
Thanks only problem is there starting to get condensation in them its like all foggy...anyone know how to fix this?
the same thing happened to my brother in laws new jetta when he bought new lights for it. he put in an oven for a while so the sealant around the sides would melt and mold the plastic together better... there might be more options and better ways to do it though
My projectors started fogging up a bit too... If you look on the back, there's little see-through white knobbies... pull 'em off, and you'll have vents for the condensation to leave through...
I've got H1s in my projectors, and they're awesome! Had to do some modding to the rad-core support, to get the passenger side light adjusted as far as I like it, but other than that, I'm loving them...Just did the quadbeam mod on 'em too, so that should light the road pretty good... |
they look awesome i want those and i also want the blacked out tails my front is allready blacked all the way out with the covers but i want to go hid so the light goes through the covers better but for now i have the covers off the headlight only have them on the turn signals for now
Wow dude. How bout using some punctuation? You know, so people can understand what your talking about?
Black is the way to go!
