Heat still blowing
Old Mar 15, 2014 | 05:03 PM
mattjphoto's Avatar
mattjphoto is on a distinguished road
Default Heat still blowing
When I turn off my heat their is still heat coming out of the vents. Is this normal for my 02 Blazer 4x4 LS?
Old Mar 15, 2014 | 05:53 PM
newguy's Avatar
you turning off just the fan or turning the heat down to cold? If you leave the thermostat on high you will still get heat
Old Mar 15, 2014 | 08:59 PM
Twip's Avatar
in my 98 i dont have to run the a/c much (thanks to cali weather) and i still get spurts of hot air that come out. the **** is almost always on cold, but the heater core is under the dash and the evaporator core is under the hood. so you are always getting a little heat. i even put mine on re-circulate and still get a little. normally not a big deal, i just kick the a/c on and blow the hot air out and shut everything off again. stays comfortable for 20-30 mins depending on how much i am driving.
Old Mar 16, 2014 | 02:43 PM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
That sounds like a blend door issue. I would do some searching here on the Forum to see if any of the other blend door problems are similar to the one you're having.
Matt2292
Apr 21, 2014 01:18 AM
davtak
Jun 28, 2011 08:47 PM
TinoMarino
Mar 21, 2008 07:11 AM
woodsballr
Jan 28, 2007 07:17 PM
cpaptogo
Mar 30, 2006 09:30 PM
