HELP! Heat blowing everywhere and NO 4X4
Old Oct 31, 2012 | 01:52 PM
Joshs4x4's Avatar
Joshs4x4 is on a distinguished road
Default HELP! Heat blowing everywhere and NO 4X4
As the title says I dont know what happened I can know that it has to be vac related any ideas on where to look?
Old Oct 31, 2012 | 02:28 PM
rexmburns's Avatar
Super Moderator
Just start checking and replacing all of your vaccum lines! It's almost easier to replace them all than try to find the one small crack that may be causing the issues. The part that sucks is the ones that go down to the transmission! I would recomend a helper so you have a person on top and bottom and them get yourself a little coupling and attach it to the end of the old hose and the new hose and pull it up through past the trans slowly one at a time. Thats the easiest way to get it accomplished. The hose is cheap its just a pain to to is all.
Old Oct 31, 2012 | 03:28 PM
05BlackJimmy's Avatar
05BlackJimmy is on a distinguished road
Do you buy just any old hose to replace the vacuum hoses? Or do you go to a parts store and ask for vehicle specific?
Old Oct 31, 2012 | 03:32 PM
Joshs4x4's Avatar
Any vac lines Its just hose.
Old Oct 31, 2012 | 03:33 PM
Joshs4x4's Avatar
Hey! there is a line that runs to the drivers fender that is just sitting there not connected to anything is that right???
Old Oct 31, 2012 | 03:36 PM
rexmburns's Avatar
Super Moderator
Yeah I know that Advance sells it as "windshield washer and vacuum tubing" The brand is Thermoid. I only know this cause I have a roll sitting here on my desk at work right now cause I need to replace all of my lines as well but since my transmission is coming out in the very near future I will replace mine then!
Old Oct 31, 2012 | 03:38 PM
rexmburns's Avatar
Super Moderator
I should go to the vacuum ball or resivoir I believe! Look for a small nipple that it may fit over either on the ball connected to your hood or in the fender there should be a black box looking thing and that will be your vacuum resivoir.
Edit: I believe yours in in the fender but I could be wrong!
Old Oct 31, 2012 | 03:40 PM
Joshs4x4's Avatar
Damn well I have to go to work but I will keep you updated.
Old Oct 31, 2012 | 03:44 PM
rexmburns's Avatar
Super Moderator
Sounds good that may fix your problems all together!!
Old Nov 1, 2012 | 03:05 PM
Joshs4x4's Avatar
I cant find anything -_-
