heres one
Old Oct 20, 2024 | 08:45 AM
TR860's Avatar
TR860 will become famous soon enough
Default heres one
so i changed my front shocks then when i went to start my vehicle (98 LS, 4.3, 4WD, 2 door, 122,000 miles) it was dead, no clicking or anything, guages dont even move...any help would be greatly appreciated...Thanks
Old Oct 20, 2024 | 12:06 PM
GeorgeLG's Avatar
Is all power lost: headlights, interior dome lights, brake lights, dash red lights at key on, radio? What is the battery resting voltage at the battery terminals? Same question at key on?
George
Old Oct 20, 2024 | 03:57 PM
TR860's Avatar
Okay dash lites were on when turned key to start they went out, So heres what i did figured i would check the battery so i got a jump and it started figured it was the battery so went while it was running and got a new battery changed it out and it started right up got home and 2 hrs later was nothing, got all kinds of dash lites and guages working till i turn to start and everything goes out lites come back on when letting up
Old Oct 20, 2024 | 04:03 PM
GeorgeLG's Avatar
Make sure that you battery connections are clean and tight
Check the battery ground connection to the frame
Get a voltmeter on the battery terminals:
  1. What is the resting voltage, key off?
  2. Same at key on?
  3. Same when key is moved to start?
George
Old Oct 20, 2024 | 07:52 PM
TR860's Avatar
cleaned battery connections, tried it when it is dark...headlights dont dim, dome light dont dim, dash lites go out except seat belt, abs, let up and all lights come back bright, radio works....was going to try the jumping thing again but neighbor aint home, have it on charger and showing 14.5 volts
Old Oct 20, 2024 | 08:16 PM
TR860's Avatar
so i tried to jump it and nothing, guy helping said it was the alternator
Old Oct 21, 2024 | 12:49 PM
TR860's Avatar
okay heres where i am....tried this morning after charging all night and nothing so i figured what the heck so i tapped the starter and it started...shut it off and hour later nothing so i tapped it again and started up....figureing the starter is bad
Old Oct 21, 2024 | 01:21 PM
GeorgeLG's Avatar
I cant help you without getting my questions answered which is fine, your truck your journey so I will bow out and let other members help you. Good luck.
George
Indrek Pringi
Nov 21, 2015 01:35 PM
jimspahr@msn.com
14
May 27, 2013 02:47 PM
Cavalier z24
Jun 1, 2012 12:30 AM
rockislife04
Suspension Tech
Apr 6, 2010 11:29 AM
strykerthat
Suspension Tech
Oct 9, 2007 06:57 PM
