Highlevel brake lights
Going to have to. Just had an engine mount break. Damaged the oil lines to the transmission as well - And also needs a new CV boot which is leaking where it comes out the front diff. Not going to be a cheap fix
I may be a little late but.
The engine mount is not to expensive, have not changed one on these yet but dosen't look to bad. (haven't really looked either.)
The trans lines you can get a piece of rubber hose and clamp it on to get it going for the time being or even long term until the rubber eventually rots out.
CV boot you can change just the boot, but I would spend the money and get the half shaft with a lifetime warranty.
I am curious to know how you added the lights though.
looks like the lights are attached to the two pieces of plastic on either side of the glass. take a look at the second picture and you should be able to make out the lights even though they are not lit.
im wondering if they are the type with the self adhisive on the back,
and you can trim them to whatever lengh you need, small surface mount
led type pehaps, i do like the look, remids me of somthing European.
no not, your a pee in... LOL
