how can i tell if my 4x4 is working when the lights for the buttons aren't working
Old Jun 6, 2011 | 05:04 PM
blazer9893's Avatar
blazer9893 is on a distinguished road
Default how can i tell if my 4x4 is working when the lights for the buttons aren't working
i have a 98 blazer with the push button 4x4 buttons. my problem is that the lights on the buttons dont work nd i dont know when 4x4 is engaged. does anybody know how i could tell?
Old Jun 6, 2011 | 05:11 PM
bscott's Avatar
bscott is on a distinguished road
Try going to an open parking lot or someplace where you can drive in circles. When your 4wd is engaged it will tug on the wheel when your making tight turns. If your making a tight turn and everything feels normal, then you are in 2wd
Old Jun 6, 2011 | 05:17 PM
blazer9893's Avatar
yea i tried that nd i felt normal. i hope the 4x4 isn't bad. Would the lights not coming on effect the 4x4 from engaging?
Old Jun 6, 2011 | 05:31 PM
Red 96''s Avatar
No, the lights may just be burned out. My light for 2wd went out and it was simple to replace. Another good way to test if the four wheel drive is working, is to put the truck in neutral, put it in 4lo, and put it back in gear. If it engaged correctly, you should feel the truck "jerk" pretty hard and almost squat down a little bit. Then, if you start driving, you shouldn't be able to drive very fast when it's in 4lo. I hope you can understand what I was getting at lol.
Old Jun 6, 2011 | 05:35 PM
blazer9893's Avatar
yea i tried putting it into neutral but i put it into 4x4 high but it didnt seem like it shifted into 4x4. im used to the 4x4 engaging on a 2500 silverado. Would it feel differant than that?
Old Jun 6, 2011 | 06:11 PM
mdehoogh's Avatar
While your truck is running, lay down next to it and see if you can spin the front driveshaft by hand. In 2WD, the driveshaft should spin freely but when you press the 4WD button, both the front differential and transfer case engage the driveshaft and it will only spin while the vehicle is in motion.
Old Jun 6, 2011 | 08:55 PM
xgiovannix12's Avatar
X2 thats the answer your looking for ^^
Old Jun 6, 2011 | 09:15 PM
chris015's Avatar
or do what i used to do and try to do a burnout lol if its in 4 you'll know it lol
or not...it'll tear stuff up...i know trust me...
Old Jun 6, 2011 | 09:22 PM
Lol bad idea . you should add that to your mistakes thread LOl
Old Jun 7, 2011 | 07:58 AM
blazer9893's Avatar
if the 4x4 isnt engaging what could it be?
