How can I tell what I have?
Been reading here but never posted so Hi!
Now thats said Im building two blazers One up and going its 1999 4x4 and I want to order fender flares cause they are Gone. How do I know if it started life as a ZR2? I will do some more searching. It does say on door it came with 31'' tires glovebox sticker long gone.
Its been down a rough road but I have running good and inside all cleaned up and all rattles fixed. First Thing I fixed was AC man its hot down here in Texas!
From what I see the ZR and standard take differnt flares. Not a Blazer guru but Im catching on. Other is 2000 with super clean body and have running good
but has a knock will rebuild this winter Im a boat bike and pwc mech and too busy right now.
The fastest and likely most useful would be to use one of the VIN decoders out there that will give you the full list of the RPO codes for your Blazer. That is what I did. It has been invaluable to have as a reference. You will likely have to pay a small fee, but it will be worth it.
BTW, I'm pretty sure the one below, also gives along with the RPO codes, it also lists the description of each RPO code for your vehicle.
https://www.compnine.com/vid.php
94blueknight
Jan 1, 2008 09:08 PM
