i am looking for 91 information on a transmission
Old Oct 12, 2013 | 11:29 AM
Terry Grieger's Avatar
Terry Grieger is on a distinguished road
Default i am looking for 91 information on a transmission
looking to find out what trans did they stick in the 91 s 10 blazer the one i have dont look like it has a spot for a TV cable.
Old Oct 12, 2013 | 12:44 PM
chris015's Avatar
do you have the 4.3? Look in your glovebox. you'll have a sticker with a bunch of 3 digit codes. Look for either m30 or md8. m30 is 4l60e (which i doubt you have as it didnt happen until early 93. md8 is a 700r4. if you have a 700,then you must have a cable or else its not going to last long. the tv cable (actually called a detent cable) controls line presssure. its not made to be tweaked for shift points,and wot shifts. if your trans doesnt shift correctly once its set correctly (google setting cable 700r4) then you have other problems.
Old Oct 12, 2013 | 01:10 PM
the tag says MD8 but the engine is different than than what was in it. It has the 4.3 vortec (W engine ) it use to have the throttle body engine ( Z engine ). But crawling under it i dont feel a spot for the TV / Dent cable.
Old Oct 12, 2013 | 03:25 PM
chris015's Avatar
OK,possibility they used a 4l60e trans,which is electric and doesnt need that cable. they came with the vin w. well,some did. to find out if its a 4l60e look on the passenger side of the transmission. look at the wiring plug in that runs to the trans. is it round or square? square is 700r4,round is 4l60e. if it is a 4l60e its gonna be a 93 or 94. 95 was usually the newer style. it did have some vin w though. are you having issues?
Old Oct 12, 2013 | 05:18 PM
yes going in to drive (if i drive it like normal ppl do) if i drive like i stold then it shifts fine.
Old Oct 12, 2013 | 05:26 PM
shifts just fine from 1st to 2nd but not into drive unless i stold it
Old Oct 12, 2013 | 07:38 PM
chris015's Avatar
if fluid level is fine(check it idling,hot.) all i can say is add some lucas trans slip to it. make sure u drain some before adding. dont wanna over fill it.
Also,it can be your throttle position sensor. its on the driver side of the throttle body. it controls shifts points. its about 30 bucks. replace it and see what happens. Oh,to help with confusion on finding parts,just ask for anything 93-94 s10 blazer thats vin w. there all the same.
Old Oct 12, 2013 | 08:33 PM
For the trans right
Old Oct 12, 2013 | 08:34 PM
chris015's Avatar
uh,yes. tps is for the trans. its on the throttle body on the engine.
Old Oct 12, 2013 | 08:38 PM
The tps I know where that is at had to replace it on my 92 same engine and the 700r4 because it has the TV/Dent cable
