-   General Chat (https://blazerforum.com/forum/general-chat-34/)
-   -   Installed New Multifunction Switch, Now Nothing Works (https://blazerforum.com/forum/general-chat-34/installed-new-multifunction-switch-now-nothing-works-74528/)
zball94 Oct 15, 2012 09:56 PM
I installed a new multifunction switch because the wiper switch was worn out. I made sure everything was exactly the way the old one was. Now I have several problems:
-No response when key is inserted/turned
-Headlight switch: dash lights come on but headlights do not
-New switch does not work whatsoever
Any ideas on what it could be? The battery was disconnected and reconnected after installation.
west iredell 381 Oct 15, 2012 10:03 PM
id check the fuses
zball94 Oct 15, 2012 10:32 PM
All fuses are intact.
xgiovannix12 Oct 15, 2012 10:33 PM
sounds like the ignition switch has a loose connection. Ya might wanna recheck your work.
zball94 Oct 15, 2012 10:38 PM
Would that cause the hazards to not work as well?
xgiovannix12 Oct 15, 2012 10:40 PM
I would think so... Does the cluster light up when the key is turned?
zball94 Oct 15, 2012 10:43 PM
Not when the key is turned, only when the headlight switch is turned.
xgiovannix12 Oct 15, 2012 10:48 PM
yea it really sounds like the ignition switch got knocked loose or something
zball94 Oct 15, 2012 10:50 PM
Alrighty I'll check that out.
richphotos Oct 15, 2012 10:55 PM
I agree with gio, sounds like a lose ignition switch connection.
