Just Got my blazer
Hi, Im new to the forum. I just got my blazer today. Its a 1987 s-10 2 door auto. The odometer has 220,000 but it doesn't work anymore. The guy i bought it from said the v.6 was rebuilt 2 years ago. Runs real good and smooth, just has a small oil leak from the oil pressure switch. needs some cosmetic work. Will get some pics soon. What engine sizes came in the 87s? on autozone it said a 2.8? i thought it was a 4.3. some help here. Thanks
its a 2.8l v6, the 4.3 started in the early 90s i believe. welcome to the forum!
The 4.3 wasn't introduced till 88 or 89. The 87 only had a 2.8, which I always thought was a bit underpowered.
Ok cool thanks. Is the oil pressure switch very hard to change out? Also my speedometer and odometer do not work. Guy said when took engine out to rebuild, they never hooked that back up. Where would I check and connect these? Fuel gauge and battery gauge work, oil pressure gauge I'm not so sure about. When it's idiling it's at 0 he when I rev it a bit, it goes up a little, could the leaky switch have something to do with this? Thanks again
5 Attachment(s)
heres some pics
i checked the speedometer cable and it is hooked up to the back of the tranny. What do i need to check for next?
if its connected at the back of the speedo then he lied, and its broken.
ok well i disconnected the speedo cable from tranny and connected a drill up to it and my mph and odometer worked. So what do i have to replace in the tranny?
going on first trip in new blaze friday. Im traveling about 2 hours away, Ill see what my blazer is made of.
