Is it just me or does it seem when one thing goes wrong on blazer everything does
Old Feb 5, 2010 | 08:40 PM
camino88's Avatar
camino88 is on a distinguished road
Default Is it just me or does it seem when one thing goes wrong on blazer everything does
Here is what i have done to my blazer since buying 10 months ago from the car dealer who said "This blazer is best car on my lot it will not need any work for at least 2 years"
3 new calipers bout $70 a piece
4 new brake lines $40 a piece
2 new front hub bearings $100 a piece
Both front and rear fluid changed $100 all together
4 new rotors $60 a piece
All of this happed with in 5 months
But despite of all this my blazer is by far my favorite car i have ever owned and i have owned at-least 14
Old Feb 5, 2010 | 08:42 PM
packofqtips's Avatar
packofqtips is an unknown quantity at this point
i paid 400 for mine last year
did tires, ball joints, front brakes, cv shaft, and a radiator so far
not to bad for a 200k mile truck
Old Feb 5, 2010 | 09:43 PM
rriddle3's Avatar
Originally Posted by camino88
"...it will not need any work for at least 2 years"
I'll bet he says that to all the boys.
What you list is not out of line for a used vehicle with an unknown maintenance history.
Old Feb 6, 2010 | 07:21 PM
Rottidog's Avatar
Amen to that! I got my '02 a year ago last Sept. under 50K miles on it. Since then (memory rewind here) <deep breath>.... plugs, wires, rotor, distributor, 4 rotors & pads, 2 front wheel bearing hubs, idler arm, pitman arm, upper control arm bushings (A-Arm) both sides, that meant a front end alignment, all fuilds flushed &/or replaced except for the brake fuild, front drive shaft, rear pinion seal & this week will be the MAF.
"if it has **** or tires, you're gonna have troubles" whomever said that was very wise lol
Old Feb 6, 2010 | 09:29 PM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
Boy! You guys really got off cheap. Bought my 94 from my nephew who didn't do anything but drive it and put gas, oil, P/S fluid and tranny fluid in it. (Do you see a trend here?) So I:
1) Replaced the oil lines
2) Resealed the oil filter adapter with new gasket & "O" ring
3) New P/S pump
4) Idler pulley and
5) Of course the belt had chunks missing so it got a new one
6) Battery
7) Rebuilt digital instrument cluster
8) Gauge temp sensor
9) Tires
10) (Only) 1 caliper & front brakes and ground rotors
11) Rear brake hardware
12) Fuel pump and sender
13) Heater & A/C control switch
14) Upper radiator shroud
15) Fixed A/C wiring - still am going to replace bad connector (just how I am)
16) Fixed interior & underhood lights
17) Right fender where battery leaked or something - only rusted out piece on truck
18) Inside driver's door handle
19) 3 window motors and replaced clips (guides) on 2 of them
20) Removed transfer case and resealed
21) New rear nount (where leaky T-case and adapter ate it up pretty good
22) Front and center brake hoses - collapsed inside and locking brakes
23) Only had to adjust parking brake cable (probably 15 turns it was that far out)
24) Put on cat-back exhaust (whole thing was toast anyway)
25) Catalytic converter (found out it was gutted after failed emissions test)
26) New Y pipe - found a few holes when the cat got changed
27) Replaced fuel pressure regulator
28) Rear window glass lift struts
29) New door lock cylinders and rekeyed glove box cylinder (used to be 3 keys)
30) New cruise/brake light switch (cured my ABS light problem too)
31) 3 U-joints
32) Replaced ashtray assembly (little tab broken off that holds glove box hinge in)
33) Replaced rear bumper, impact strip and trim piece and painted
34) New O2 sensor - Check engine light came on on way home from failed emissions test
35) Am in the process of replacing center console with a 2nd gen model
Still need to do some front suspension work - ball joints, etc. Spent a lot more than I'd planned helping out the relatives. I'm sure there's more but I just can't remember everything. Old age creeping in. Sure glad I didn't have to pay anyone to fix this thing. But I love my truck!
Old Feb 6, 2010 | 09:42 PM
ve3nsv's Avatar
ve3nsv is on a distinguished road
99 GMC Jimmy
New lower ball joints
Front passenger ABS sensor
Thermostat
Rear brakes pads and rotors
Drivers side rear caliper.
U-joints on rear shaft
Now working on...
Intake gasket...boo
Front and rear pinion seals
Front u-joint while the shaft is down for the pinion seal.
Old Feb 6, 2010 | 10:31 PM
Rottidog's Avatar
ok Gimpy... but how many miles?
thats a 1994, i have a 2002 with under 50K on it... but thats still a chitload of stuff I agree
Old Feb 6, 2010 | 11:56 PM
Believe me I still have a ways to go. I don't think anyone ever did anything to this exceot just enough to keep it running (which it didn't when I got it). It sure has been a learning experience though. I also have a 84 S15 Jimmy that I sadly had to repo from young son that'ss in pretty rough shape. It's only got about 120,000 on it. BTW how do you like your body lift? I can't decide 2" or 3".
Old Feb 7, 2010 | 09:45 AM
Rottidog's Avatar
I love the BL. I have 31's on it now & hopefully this upcoming week I'll have 33 x 12 1/2's.
The 3" lift was on the truck when I got it & they didn't install the bumper brackets. If you do go 3" & install the bumper relocation brackets then you may have to modify the rear one because it changes the geometry of the hitch receiver or you won't be able to tow. The bumper bracket & receiver plates are integrated at the frame.
Old Feb 7, 2010 | 10:38 PM
Thanks man. I see a 2" in my future. God knows I've put enough work in this creampuff as well as coin and would really like to start restoring my JimmY (again). Of course this is after I have to fix a Nissan Altima that the cams are out of time with the crank. (Broken tensioner as the chain is loose as a goose and zero compression on all cylinders) But it turns over and the valves aren't hitting the pistons. Must be a common problem. O'Reilly makes a kit just for this. This will probably be for another one of the relatives but I've implemented a new policy. Pay now, drive later.
