Manual T-case Shifter After 3" Body Lift
Old Sep 2, 2012 | 09:31 AM
91chevywt's Avatar
91chevywt is an unknown quantity at this point
Default Manual T-case Shifter After 3" Body Lift
I have a '94 Jimmy that I fitted with the NP231 T-case, using the stock blazer shifting mechanism. After doing a 3" body lift, the transfer case shifter sits very low in the console. While functional, it looks bad. Is there anything out there to extend the shifter up a bit?
Old Sep 3, 2012 | 06:03 PM
neo71665's Avatar
What I done was cut it right above the threaded section, welded in 1/2 rigided pipe (electrican had it) and to extend the rod for the button I used a welding rod cut to length. I added 3 inches to mine and its about 1/2 to 1 inch taller than stock. I also had to bend it back a few degrees. I cut cut the pipe I welded, bent it back, welded it under where the rubber boot sits.
matthewp
Apr 4, 2021 09:16 PM
jasedude
Nov 24, 2010 04:03 PM
whitejimmy
Lifting Tech
22
Mar 8, 2010 02:50 PM
rbcar1
Dec 13, 2009 10:20 AM
midnightmekanik
Oct 8, 2009 08:32 PM
