Misfire
Hello,
I have 01 LS 76,000 miles. Driving through WV last night my car misfired (service eng light flashed) this is not the first time it has happened. I replaced the gas cap and my spark plugs and wires over the weekend and now I don't have a clue why it misfired. Any ideas? |
RE: Misfire
Ashley, did you have the diagnostic code read? This would help with trying to figure out what the problem is.
RE: Misfire
It came up as random misfire p0300.
RE: Misfire
Last time I had a misfire in my 01, it turned out to be a bad plug and wire. Just double check all your wires and make sure they are in tight.
RE: Misfire
If you have not replaced the distributor cap and rotor, this would be the first thing I would do and see if it helps.
