Motor Mounts
Old Mar 22, 2010 | 05:16 PM
fondo's Avatar
fondo has a little shameless behavior in the past
Default Motor Mounts
I know this has been asked millions of times and I've searched and found some useful info but I like to stir up the water. My 93 bravada motor mounts are junk and I'm contemplating whether or not to change 'em while I've got some time. What all does the job entail for replacing these mounts. I've read that I need to unbolt the y-pipe and remove the radiator shroud but what else? Do the fuel lines, coolant lines, ps lines, and distributor need to be removed as well? How much of bitch is it to unbolt the mounts once I get the motor suspended? Just fill me in... Thanks.
Old Mar 22, 2010 | 05:25 PM
jacobcnc's Avatar
jacobcnc is on a distinguished road
When i did mine all i did was take off the hood, remove the center bolt. Lift one side up take off the block and replace. Lower the block put center blot back in. Mine is a 96 so it might be different.
birdsfan82
Jan 30, 2010 11:18 AM
Woober
Jul 19, 2009 12:19 AM
justin1795
Feb 26, 2009 02:30 PM
lionel2
Feb 4, 2008 12:32 PM
mmench
Aug 27, 2007 02:17 PM
