mpg?
I was wondering sence m geting 17 mpg right now stock. How much would i get 2001 Chevy Blazer 2wd with 2 inch body lift, 31/10.50/15 all terains, roof rack with spare, and stock 3.42 gears? And how would i get my mpg better once i do all that? Would a tune up help?? Thanks
Everything you are thinking will decrease your milage. Body lift= worse aero. 31X10.5 more rotating weight, three times worse than sprung weight. All terrains=worse rolling resistance. Roof rack= worse aero as well as higher center of gravity, way worse with the tire up there. Then you wanna know how to get better milage? Sorry but I just dont understand. Kinda like saying you like riding the girls on the corner bareback but want to avoid seeing the doctor.
^^ Lol... good analogy. But i would guess you will get about 4mpg less than you do stock. I have everything on my truck that you want on yours and i get about 14 mpg average with city and highway mixed. I took my roof rack off (i didn't even have anything on it) and now i get 2-3mpg better on the freeway, i had no idea it affected my gas mileage that much but needless to say its staying off unless i need it lol. I also have a PCM tune from Wait4Me performance and that helps the mileage a lot. Basically with with a 2" bl a 2" suspension lift and 31's with 3.73 gears i get about stock mileage with the tune. Since you have 3.42 gears city will be harder and OD on the highway will be sluggish
Originally Posted by 97cherryblazer
(Post 593236)
The air under the Blazer is just as dirty as the air over a basket it just doesnt have the area. The chevy rack isnt too bad. But a basket with lights, even worse. Doctor I only did her once, honest
(Post 593236)
And can I get a pcm from junkyard and send it in?
You can get a junk yard PCM however it has to be the right year and some numbers on it have to match yours, i don't remember which ones tho. I tried to get one but couldn't find one that would work so i just sent them 160$ and they sent a tuned PCM. So i have two now which is nice
Ok thanks and are they worth it with 31s? And if I keep stock gears will getting a pcm give me the loss in power back??
They will set up your gearing to compensate for the tires (they also correct your speedometer) and the tune adds power so it won't be as noticeable as it would be stock but you will see difference. You will still notice the power difference in city, way more fun to drive but highway may seem more sluggish than normal.
| All times are GMT -5. The time now is 09:36 AM. |
