my blazer
my blazer
tell me what you guys think, its a 97 with 57k, my only problem is i have water leaking on drivers side floor, its coming from the dash area, any suggestions?
so far Ive put in the fogs, Sony radio, Sony xplods front and back, interior blue lights,
On the to do list
-fix leak
-flowmasters
-k&n air filter
-subs
-strobe lights
-tailgate light strip
-bigger tires.
-maybe a pushbar
(the jeep is my buddies)
On the to do list
-fix leak
-flowmasters
-k&n air filter
-subs
-strobe lights
-bigger tires.
-maybe a pushbar
NIce truck & welcome to forum!
1st suggestion would be using the search feature & search for "coolant leaking into passenger compartment". Change the wording up & get different results. I'm sure you'll find threads about heater core issues, blend doors, vacuum issues, hoses etc.
Very nice I looked at a Jeep like your buddies before deciding on the Blazer. It needed more work.... I think with your leak is something that could be a front windsheild replacement... Something to look into because it can cause further issues other than just a puddle at your feet.
Didn't know it was only during rain.
My 2002 had a bad door seal (fried mirror controls) & a windsheild seal that leaked right above the rear view mirror... but only after 45 mins of rain.
Many say water when they mean coolant, sorry. My bad for assuming.
Typically, a heater core leak will only put coolant (sweet smelling) down on the passenger side and this would occur regardless of the rain. This sounds more like a door seal/windshield seal issue. Try running a garden hose over a suspect area till you see the wet on the floor to confirm where the leak is... good luck
