need a HD transmission flush
Old Nov 5, 2013 | 03:31 PM
rexazz2's Avatar
Default need a HD transmission flush
SOOOOOO
My auto slush box transmission in my Civic started acting up in the cooler weather
Cold it would really slow shift almost like it was going into neutral
Found if it warmed up it wasn't so bad
But the colder it gets the longer blah blah blah
Last night I checked the fluid and it was in between the lines so I thought I would top it up with Lucas transmission fix
That was a huge mistake , it wont so much as move an inch
Turns out there is a non serviceable screen type filter inside the transmission and I am guessing its now starving for fluid
There is no transmission pan , but there is a drain bolt
Curious if any body has ever chemically flushed a transmission , figure someone here has submerged in water and had a really big mess
Old Nov 6, 2013 | 02:22 AM
rexazz2's Avatar
bump
considering draining what I can and dumping in some varsol
then flushing with transmission fluid
hroofblaze96
Jan 15, 2020 04:39 PM
pfsantos
Sep 23, 2010 03:58 PM
portcqb
Apr 29, 2008 09:56 AM
Chadoo951
Dec 27, 2007 04:42 PM
ZR 2
Dec 4, 2007 03:53 AM
