need help please!!!
Old May 4, 2013 | 02:45 PM
larryap's Avatar
larryap is on a distinguished road
Default need help please!!!
I have a 1999 Chevy blazer 4x 4. The security light is blinking and it will not start. It cranks and has fire, but no go. I've replaced the fuel pump, distributor cap rotor, crank sensor. Even tried turning key to start position to reset it. Any ideas?? Thanks in advance.
Larry
Old May 4, 2013 | 03:39 PM
ohsofly's Avatar
Passlock sensor in the steering column... Do you by chance have a key ring that has a ton of keys or weight hanging off it? People who have heavy key rings wear out ignition tumbler parts and passlock sensors due to the weight hanging off the ignition.
You can try this:
http://www.justanswer.com/uploads/JH..._procedure.pdf
But if that doesnt do it, then you most likely need to replace that sensor.
Old May 4, 2013 | 05:22 PM
larryap's Avatar
Can you bypass the security system? If so, how?
Old May 5, 2013 | 11:28 AM
ohsofly's Avatar
Im sure some car stereo/alarm shops would know how to do it... but why? Why not just fix it?
opposedforces
Sep 1, 2011 02:59 PM
rogggg1020
Nov 11, 2008 08:05 AM
pdljr04
Aug 15, 2005 04:56 PM
blazin4eva
Jan 27, 2005 02:02 PM
