need help with rear end
Old May 19, 2013 | 10:52 AM
emartin's Avatar
emartin is on a distinguished road
Default need help with rear end
So I blew the rear end out in my k5 and I need to know what gear ratio is in an 88 k5 blazer it was the stock rear end. Any one who could help that would be great
Old May 19, 2013 | 11:09 AM
cleburne red's Avatar
There are Vin decoders that might tell you. Or you could make a mark on your drive shaft and spin the wheel one time. However many times the drive shaft rotates is your gear ratio. It won't be exact, but if it spins three and three quarter times, then you've got a 3.73:1. You could also take the gears out, count the teeth on the ring and on the pinion and divide them. That will give you the cast ratio.
doktornasty
Nov 3, 2013 03:12 AM
MXCowboyTX
Mar 6, 2013 01:18 PM
787
Aug 7, 2012 08:18 PM
shotnva777
46
Oct 12, 2011 09:07 PM
brino1
Feb 25, 2011 08:05 PM
