Need help!! Rpms don’t drop
Old Jan 20, 2023 | 01:27 PM
JessenU's Avatar
JessenU is on a distinguished road
Originally Posted by GeorgeLG
The way to test your TPS is to watch its value in % at idle running and then key on engine off as you move the accelerator pedal slowly back and forth through the full travel and watch for erratic or improper readings. This would be especially good during a high rpm event. There are various scanners that can look at TPS, the most cost effective (around $40) being the BT dongle/Android apps. Les can tell you which ones report this parameter. The usual suspects:
Car Gauge Pro
Car Diagnostic Pro
Torque Pro
Dash Command
There is also a comprehensive hardware solution if you are willing to cough up $150: Vident ilink 400. Above that are the stupid expensive scanners (ask me how I know) like Tech 2, Snap On, etc.
George
I’m going to double check the autel one more time, then will start looking into new scanners. Maybe I missed it In the 14 times I’ve looked thru it. Will update later tonight
Old Jan 20, 2023 | 02:47 PM
LesMyer's Avatar
Any scanner that does live data should read TPS. Bet the Autel does that one - just need to find it. Throttle angle?
Old Jan 20, 2023 | 02:56 PM
rockp2's Avatar
What model Autel do you have? Also, sometimes when a PID doesn't seem to be available when you enter your VIN or model specific into the scanner you can find it by selecting instead "Generic OBD" and looking at the Mode $6 data.
Old Jan 20, 2023 | 09:50 PM
JessenU's Avatar
I’ll have to look in the morning, but I think I remember seeing a throttle angle one. Will double check tomorrow.
I don’t know off the top of my head, will check tomorrow morning I guess. Not really wanting to waste time out in the cold tonight
Thanks for all the quick responses guys!! Much appreciated
Lgarretto
Lowering Tech
Oct 25, 2021 08:28 AM
Old Skool Soldier
Apr 18, 2012 10:07 PM
02bluxtreme
Lowering Tech
Oct 12, 2009 07:05 AM
middleman496
Aug 10, 2007 02:02 PM
blazin97
Suspension Tech
Dec 13, 2004 12:06 AM
