Need help with towing info ASAP
Old Oct 1, 2017 | 02:08 AM
Amplife's Avatar
Amplife is on a distinguished road
Exclamation Need help with towing info ASAP
Me and my fiancee were lucky enough to be give an 89 blazer S10 for parts, is it possible to tow an 89 blazer S10 with an 89 blazer s10? on a tow dolly? We only have to tow it about 25 miles at most and it's mostly slow back roads. Also how do I disengage the driveshaft for towing?
Old Oct 1, 2017 | 04:16 AM
Should work.
Make sure the dolly is up to specs and can be correctly fixed to your S10.
To remove the driveshaft you loosen two brackets on each end where it is fixed to the yoke.
Bring 4 zip-bags and be extra careful once it is out because the cups which were held by the retainers (brackets) are just pushed over the axle of the joint and contain the needles. You may want to bring a large piece of cardboard to put under the truck. Makes life easier and the needles when lost are easier to find.
Another method is to detach the driveshaft and put tape around the end to keep the caps.
I prefer detaching the whole driveshaft no hassle under the car and the work is not that hard.
When detaching just at the differential is where you have to be extra careful. The driveshaft must under no circumstance hang from the truck, it has a sliding piece which has to be secured in such a way that it cannot extend, else it may hit the rotating yoke on the differential or other parts. It cannot in any circumstance move to somewhere where the suspension or the axle is.
This is where sturdy wire comes into play. For the first you can fix the sliding part and put a wire from end to end to keep it compressed. And the wire can be used in some smart place to hold the driveshaft up to the body.
BRING:
- something to mark the brackets e.g. F1/F2 R1/R2 and direction (I do that others simply don't care) such as cheapest nail enamel, paint marker...
- zip-bags for the parts
- tape
- cardboard
- toolbox
- sturdy wire at least a couple yards
- pliers and cutter
Good luck
Old Oct 3, 2017 | 12:50 AM
Do not use 4th gear (overdrive) and watch the temperature of the motor. Excessive shifting can cause overheating of the transmission fluid which will cause irreversible (and expensive) damage. Stay slow, no more than perhaps 45 mph. That you will be using back roads for a shorter distance is good.
Also, you will be towing as much as the tow vehicle weighs. Your braking will be very difficult. Be very careful and exercise quite a bit of situational awareness so that you are not surprised by anything that would make you brake unexpectedly.
Christine
Mgiudice
Apr 24, 2011 11:03 PM
g_mike
Dec 14, 2010 08:48 PM
LTblaze
May 9, 2007 11:05 AM
91BlazerTahoe
Feb 16, 2007 03:17 AM
XBlazer01
Nov 12, 2006 12:21 AM
