no interior lighting
Old Nov 12, 2013 | 11:40 AM
blazefan's Avatar
blazefan is on a distinguished road
Default no interior lighting
I have a 2000 blazer and when I open the doors the inside lights do not come on. I can override them to confirm the bulbs are working...and when I press the remote unlock they come on?? Also, the radio goes off when I turn the key off (it usually stays on for a short time)
Any ideas on this?
Old Nov 13, 2013 | 08:30 AM
Smitty Smithsonite's Avatar
Sounds like a short between the door switches and the lights, or just a bad switch. Reason I think it's a short is because the radio immediately shuts off when you remove the key. Either that, or the Body Control Module (BCM) is bad.
These things weren't noted for their "robust" electronics ...
Old Nov 13, 2013 | 03:44 PM
rexmburns's Avatar
Super Moderator
Moved To: Lighting & Electrical
Old Nov 13, 2013 | 05:42 PM
The RAP, (retained accessory power) relay, timer, fuse or circuits may have an issue. That is the system that keeps power applied, (for a few minutes) to certain accessories after the key is shut off, and before the doors are opened. Some of the circuits do go through the BCM, but not all of them. Check the basics, if you come up empty, you'll need a bi-directional scan tool capable of accessing and commanding the BCM & network.
Old Nov 13, 2013 | 06:58 PM
blazefan's Avatar
thanks I will give it a try
Old Nov 13, 2013 | 06:59 PM
blazefan's Avatar
a little out of my scope of practice but will give it a go...thanks
dlboyd
Apr 5, 2010 08:06 PM
90Conan
Feb 25, 2010 06:11 PM
chrisblaze
Dec 6, 2009 12:27 AM
OlnytheBowtie
Feb 22, 2009 02:58 AM
Tony2009
Dec 21, 2008 10:47 PM
