Oil change.
I am changing the oil in my blazer tomorrow. I was just curious, is there a specific ft-lb rating the oil drain plug should be torqued to? I usually don't care, but I have found myself looking for excuses to use my new torque wrench..haha
BTW, did anyone see where Advance Auto Parts has gallon jugs of Penzoil (all weights) for $7.96 each ($3.42 off of reg. price) until the 29th?? also $1.99 a quart till the 29th.. |
RE: Oil change.
no i just tighten mine just about as tight as i can go so i can get it off next time too. but ya plz do not use penzoil it creates sludge a lot and thats bad for engines. my dad is a mechanic and has seen penzoil destroy engines quite a bit
RE: Oil change.
ive never had trouble with it, nor had my grandpa (also a mechanic for over 50 yrs)... so I will continue to use it till I do have a problem...
RE: Oil change.
[align=left]15 to 20 ft-lbs if you really want to be picky about it. This comes from the haynes repair manual.
[/align] |
RE: Oil change.
I think thats anyone, who looks for excuses to use a new tool!!! LOL
RE: Oil change.
I would say 15 since that what it says in the chilton book I also have the haynes manual and it says 15-20. If it hasn't clicked and you have it set to 15 just go as tight as you think resonable so you dont strip the bolt or threads.
RE: Oil change.
well, as soon as my engine cools, I will be going outside to change my oil. Summertime is almost here so its time to go back to 10w30 instead of 5w30. Also going to flush my heater core and add some more Dex-Crap compatible prestone 50/50..... anyone done a how-to on a quick heater core flush?
RE: Oil change.
ORIGINAL: 94blueknight no i just tighten mine just about as tight as i can go so i can get it off next time too. but ya plz do not use penzoil it creates sludge a lot and thats bad for engines. my dad is a mechanic and has seen penzoil destroy engines quite a bit |
RE: Oil change.
ORIGINAL: dbleon ORIGINAL: 94blueknight no i just tighten mine just about as tight as i can go so i can get it off next time too. but ya plz do not use penzoil it creates sludge a lot and thats bad for engines. my dad is a mechanic and has seen penzoil destroy engines quite a bit (side note: w00t to my 1000th post! kinda cool thing but ya i'm on this forum the most and its the best) |
RE: Oil change.
Try the max life man... it lasts just as long as a syn. and you can get it at wallmart for ~$12... I was changing mine at 3K but i felt bad wasting perfect oil, so i switched to 5k... My dad goes 15k intervals on the max life in his toyota (all freeway driving + he's a cheap arse), and when i change it it still looks deccent.
