Over Drive vs. Drive
Just to be 100%, OverDrive is the "D" with the "O" in the center.
Anyways, As I have read online, using OD for city, highway etc. is recommended but I should use "D" drive for towing.
I had the truck out today with the trailer with the bike on it and used it in "D" and when on the highway for the heck of it I put it into "OD" and the RPM's dropped a couple thousand and had no issues. Wondering if when on the highway at highway speeds if I should put into "OD" and use "D" when in city and hills. With the RPM difference would think I would be buring more gas when at highway speeds when in "D" drive.
You should be using overdrive unless you find the transmission constantly down-shifting and up-shifting as you are keeping speed. To drop down into 3rd when under 40-50mph will only accomplish one thing, decreasing your fuel mileage.
Again, if you can hold your speed, even while towing, in OD, there is no reason to shift down to 3rd. It is a matter of heat buildup. Constant shifting produces heat. If the torque converter unlocks, it produces heat. You want the least amount of heat.
t.lyttle
May 10, 2009 06:04 PM
