Prep for vary cold night
gona be -30f tonight so is there anything i should do to prep for tonight or not?
another thing I'm worried about is my electronics like my amp, subs, and the deck. Will the cold do anything to them or not? I asked befor in a different post but it wasent as cold back then only like -10f so this is frezzing cold
my power mechanics teacher said to fill the tank and that when i start it to just let it sit and idle for a bit befor driving off
RE: Prep for vary cold night
if you got a block heater plug it in, full tank of gas with some gas line antifreeze. no need to worry about electronics. if you run synthetics that helps also.
Just do NOT crank up the stereo and you'll be fine.
The amps aren't going to have a problem... It's the speakers and subs that will.
If you don't have a block heater, I'd reccoment letting your truck sit with a charger over night... You're gonna need some good starting oomph... Especially if you've got the AC Delco battery.
You don't NEED a block heater at that temperature, but it's easier on the vehicle.
And dress up
And dress up
Wasn't there an earlier post about in the extreme cold parking a certain way if you're on an incline? I thought it was front end higher than back end to keep oil at the pump at start up..could be wrong though.
It was -35 celsius last night here (about - 31 f) and I did not plug my blazer in. It started second crank no problem at all. Gotta love GM
it's only going to -30? just put a coat on! kidding.... seriously tho, the best advice i can give is plug in if you have a block heater. i'm currently driving a P.O.S. government vehicle (ford explorer) until i pick up my jimmy this weekend, and it's -48C (or -54F) up here. With it plugged in at night i've never had a problem starting it, but definitely let it run for a few minutes (8-10min if you can spare it), and even then take it easy for the first few miles.
your engine will be warmed up from the block heater/idling, but you're tranny sure as hell won't be...thats one thing i noticed once it dropped below -30C, that you'll feel like you hit a pothole on the first few shifts, and it's probly not good at all on the gears, so just take it slow until you get some of that jello-like fluid warmed up and circulating.
i agree with cliro, definitely get a full tank of gas, and don't forget the gas-line antifreeze. you definitely don't want to find out the hard way that you got a little water in your gas and it froze up your lines. be very careful how full you get your tank tho, once the pump handle stops, don't squeeze out that extra few dollars. i was used to doing that back home, and i filled up the ambulance at work last week and once we parked it back in the nice warm garage the freezing cold diesel expanded and we got a nice puddle of fuel on the floor.
my last piece of advice is lube up your door locks, get a nice lube/de-icer combo (there are plenty at any hardware store) and give the locks a squirt ahead of time, to make sure that you can get in the next day....all the prep in the world to keep the motor/fluid warm won't do you any good if you can't get in!
hope all this helps!
-Yukon Medic
-Yukon Medic
u should be fine i rem last yr when we had that week of below zero temps where it would get to -30*F below zero and that was the actual temp not the wind chill and it was like that for a week and i didnt do anything to my blazer it was just parked in my driveway as usual and it started up fine just cranked a lil longer but started right up took awhile to warm up too lol gm ingintion systems are powerful! i had no metal tip in my cap and my engine ran fine lol
ORIGINAL: WolfPack
Doesn't really matter how you park...
The only difference is, if your grill is facing the wind, it's going to take longer to warm up.
well this morn it was -10*F out w/ a windchill of -35 and the blazer started up just fine a lil low tho but duh its figgin cold out!! the cold doesnt matter to my blazer
it started up just fine so yeah...
