Pro Comp Suspension TH6B Tow Hook
Old Feb 14, 2011 | 09:29 AM
CraigSnedeker's Avatar
Default Pro Comp Suspension TH6B Tow Hook
http://www.amazon.com/Explorer-Pro-C.../dp/B000CNGVAS
Any idea how good those are? I can get them for $4 new.. that seems cheap, just wanna know if they are worth it thx
Old Feb 14, 2011 | 06:52 PM
ABN31B's Avatar
how good? i dunno... but ask a jeep guy, they would have the best experience with those. Most have something very much like that on their Wrangler's front bumper. which is why the holes are set to that specific distance and dia...
Ask me how I know
Old Feb 14, 2011 | 10:06 PM
old skool luvr's Avatar
oh, i'm sure we can take a pretty good guess.
everything is good 'til it breaks.
personally, i think it looks kinda skimpy-especially right @ the bolt area. plus, there's no weight rating on it.
Old Feb 14, 2011 | 10:24 PM
ABN31B's Avatar
weight rating is 5 ton.
should be fine so long as you equalize the load across both perfectly
AND
pull straight
AND
they are mounted securely to your frame
AND
i would suggest a backing plate
AND
they fit your mounting holes
AND
you use some good mounting hardware.
problem will be the fit though...
grab a set from a parts store and test fit vs current hook
Old Feb 14, 2011 | 10:53 PM
where'd you find that info Curtis?
Old Feb 14, 2011 | 11:05 PM
ABN31B's Avatar
Summit FTW!
also the 3 hole sounds promising if the extra hole fits our gapped out hook style
Old Feb 14, 2011 | 11:57 PM
oh, ok.
i knew i hadn't noticed the weight rating on the OP link. but when i checked again, i knew you had to have had an ace up your sleve somewhere..............
Old Feb 15, 2011 | 03:41 PM
ok, thanks
DunnDunn116
Tires and Wheels
May 14, 2010 03:46 PM
jdell1107
Tires and Wheels
May 14, 2009 08:59 AM
new03blazer
Tires and Wheels
Oct 28, 2006 01:27 AM
a_tack
Oct 11, 2006 11:13 PM
88s10Blazer
Tires and Wheels
Jul 6, 2006 06:49 PM
