Question
My buddy & I did a oil change on my truck and he said it looks like I am going to need to get the end links for the sway bar. I'm not too sure what he was talking about. Any ideas. How much a Front Sway Bar for a 2001 4dr blazer goes for?
RE: Question
They do have sway bar repair kits which come with the links they are like $15
ill see if I can dig up some more info |
RE: Question
Thanks... This is what I am need of...End links for the swaybar
RE: Question
Energy suspension endlink kits are dirt cheap! Under $20 for both sides for poly bushings. Easy to change out too. I don't even remember jacking up the front of the truck to do it.. Just turned the wheels to the right and replaced the right side, then back to the left to replace the left side.
RE: Question
Thanks Kyle
RE: Question
Kyle,
is there a website for the Energy suspension endlink kits? |
RE: Question
Well, yeah, Kevin, how 'bout http://www.energysuspension.com/. :)
RE: Question
EnergySuspension.com for the part numbers. They used to be available at Advanced Auto, but I don't see them on their website anymore. I believe it was 3-5206 for the 28mm sway bar bushing set (which includes the sway bar to body mount bushings) and 3-5207 for the 33mm sway bar set.
Pretty much any poly set will last longer than stock. |
RE: Question
ORIGINAL: swartlkk ...I believe it was 3-5206 for the 28mm sway bar bushing set (which includes the sway bar to body mount bushings) and 3-5207 for the 33mm sway bar set. |
RE: Question
Hey any help I can get since I don't know a whole lot about kits for sway bar stuff. Kyle hasn't givenme any bad information with the parts he suggusted I order.
