Question
Old Jan 29, 2008 | 08:40 AM
quinnman105's Avatar
quinnman105 is an unknown quantity at this point
Default Question
My buddy & I did a oil change on my truck and he said it looks like I am going to need to get the end links for the sway bar. I'm not too sure what he was talking about. Any ideas. How much a Front Sway Bar for a 2001 4dr blazer goes for?
Old Jan 29, 2008 | 09:03 AM
c0a8l0v6i8n9's Avatar
c0a8l0v6i8n9 is an unknown quantity at this point
Default RE: Question
They do have sway bar repair kits which come with the links they are like $15
ill see if I can dig up some more info
Old Jan 29, 2008 | 09:15 AM
Thanks... This is what I am need of...End links for the swaybar
Old Jan 29, 2008 | 09:16 AM
Energy suspension endlink kits are dirt cheap! Under $20 for both sides for poly bushings. Easy to change out too. I don't even remember jacking up the front of the truck to do it.. Just turned the wheels to the right and replaced the right side, then back to the left to replace the left side.
Old Jan 29, 2008 | 10:19 AM
Thanks Kyle
Old Jan 29, 2008 | 02:35 PM
Kyle,
is there a website for the Energy suspension endlink kits?
Old Jan 29, 2008 | 02:47 PM
rriddle3's Avatar
Well, yeah, Kevin, how 'bout http://www.energysuspension.com/.
Old Jan 29, 2008 | 02:49 PM
EnergySuspension.com for the part numbers. They used to be available at Advanced Auto, but I don't see them on their website anymore. I believe it was 3-5206 for the 28mm sway bar bushing set (which includes the sway bar to body mount bushings) and 3-5207 for the 33mm sway bar set.
Pretty much any poly set will last longer than stock.
Old Jan 29, 2008 | 02:52 PM
rriddle3's Avatar
ORIGINAL: swartlkk
...I believe it was 3-5206 for the 28mm sway bar bushing set (which includes the sway bar to body mount bushings) and 3-5207 for the 33mm sway bar set.
Good grief, Kyle, what kind of memory powers do you have?!
Old Jan 30, 2008 | 08:28 AM
Hey any help I can get since I don't know a whole lot about kits for sway bar stuff. Kyle hasn't givenme any bad information with the parts he suggusted I order.
