Quick ?
Old Dec 14, 2009 | 05:46 PM
fondo's Avatar
fondo has a little shameless behavior in the past
Default Quick ?
Which way should I rotate my tires?
Old Dec 14, 2009 | 05:57 PM
Sisk's Avatar
That would depend on whether or not your tires are directional. If they are, then you'll have to go front to back (keeping the same sides). If not, then you should probably go in an criss-cross X pattern (front left becomes rear right, etc).
Old Dec 14, 2009 | 06:00 PM
ABN31B's Avatar
assuming full sized spare on matching rim
Old Dec 14, 2009 | 06:36 PM
Sisk's Avatar
Again, be sure your tires aren't directional before going criss cross.
Old Dec 14, 2009 | 08:39 PM
old skool luvr's Avatar
you should just rotate your tires front to back & back to front, not switching sides.
there are alot of people who say you can change the direction of a tires rotation, but i'd have to disagree. i've had tire go from one side to the other, and end up having problems with them (cords failing, trea seperation, etc.)
Old Dec 14, 2009 | 08:48 PM
cbr995's Avatar
Front to back. You should keep a tire going in the same direction throughout it's life. The belt and cords are used to going one way, and you could have possible cord separation, which isn't too good.
Old Dec 14, 2009 | 09:40 PM
gee, that sounds awfully familiar................
Old Dec 14, 2009 | 10:09 PM
grantd's Avatar
grantd is on a distinguished road
Majority says front to back and I agree sounds logical.
Old Dec 15, 2009 | 10:13 AM
ABN31B's Avatar
then when you rotate your tires, make sure to check your spare for rot and under inflation
Old Dec 15, 2009 | 10:32 AM
WolfPack's Avatar
So don't drive in reverse?
I do the forward cross as per the owners manual, but I have A/T, non-direction treads.
