Rear differential
Old Jul 31, 2012 | 05:02 PM
chvmanothree's Avatar
chvmanothree is on a distinguished road
Default Rear differential
Do i have to take the traction bar off that runs across the pumpkin cover.. in order to take the cover off to change the rear differential fluid?
Old Jul 31, 2012 | 06:27 PM
warthogdriver's Avatar
it depends...you didnt tell us what your driving
if its a 4 door 99 like mine then no. i didnt...but it would make the job easier.
Old Aug 1, 2012 | 05:40 PM
step66's Avatar
warthog is right:you do not need to remove sway bar(if this an s series Blazer) but it is a tad trickier getting the cover back in place with a new gasket and sealant leak-free w/o disturbing the sealing medium! My 97 GU6 axle I had to do twice due to my ineptitude with that! But that was now 3 years ago...
Old Aug 1, 2012 | 06:12 PM
Default Kewl
Thax , stepp66
I have a 2003 LS 4door 4wheel drive. the sway bar is pretty close and i can see it will be hard to put back with out distrubing the new gasket!! So i guess my next question is...can i take the sway bar off or loose with out messing the rear alignment up or anything??
Old Aug 1, 2012 | 08:54 PM
there is no rear alignment on these riggs.
you can remove the bar, but you may have to get new u-bolts to get the sway bar off...i am guessing the rust is gonna put up a fight. you can try to soak the bolts in p.b. blaster..that may help.
Old Aug 2, 2012 | 04:43 PM
Default thax
Thanks alot warthogdriver... I didnt think there was a rear alignment.. but me i seem to tear up more than iam tryin to fix!! and i have to say there hasn't been a bolt i havent got off yet... iv torched a few and cut a few but i never give up. and yes i will get new U bolts..cause i got the same feelin..does rusted old bolts are going to put a few more gray hairs in my thick skull... Thax again.
Old Aug 5, 2012 | 08:56 AM
So i got the pumpkin cover off and drained the fluid, got the cover and new gasket on, went to fill it up ..and i cant get the freakin PLUG out!! and now the hole in the plug is rounded out and the socket end is not going to get it.. What do i try next?? do they make a special tool for that? i know this has to happen to others...or is it just my darn luck!! HELP))))))
Old Aug 5, 2012 | 11:13 AM
05BlackJimmy's Avatar
05BlackJimmy is on a distinguished road
If you have access to a welder you can try grinding off the rust and welding a nut on it.
Old Aug 7, 2012 | 02:56 PM
Default Shocks
So who sell's a heavy duty rear shock for a 2003 blazer LS? These light weight shocks seem to be pretty much junk
Old Aug 7, 2012 | 03:04 PM
USMC3782's Avatar
USMC3782 is on a distinguished road
i got my rancho 9000xl's from 4wheelonline.com. very happy with the ship time and service. your truck may not need adjustability etc depending on what you do with your truck. I tow, off-road and also do a good bit of highway driving. their prices were very good. if you want also check rock auto. they have shocks starting under $20 iirc.
Drew4711
Oct 6, 2012 12:47 PM
98BlazerLT4x4
Mar 4, 2008 06:00 PM
MusicMaverick
Apr 21, 2007 02:17 PM
myetman
Apr 14, 2006 01:46 PM
Binz316
Apr 12, 2006 12:55 PM
