Rear end question?
Hi
i have a 1998 2wd blazer and the rear is on its way out. I have the 7 inch ring gear with a gu6 or 3.42 ratio. I wanted to know if the 4wd blazer (2001 rear which is an 8 inch ring (gu6 ratio is compatible to my truck. And is it a easy swap rear or does it require modifications. Thank you |
Originally Posted by Brian Cockerham
(Post 725122)
Hi
Something else to consider; the 01 4x4 axle is most likely a disc brake setup too, whereas the 98 2wd is most likely drum.
