recline handle broken?
is it the plastic handle that broke or the metal/aluminum rod it connects to?
my handle is fine but the rod it connects to broke, so i had the handle drilled out to the same size of the rod so it would slip over what was left then drilled a hole through the handle and rod and out in a nut and bolt kinda like using it as a pin, then i packed it with jb weld... it seems ok but i havent driven it so it hasnt really been used.
Pain in the ****! Those damn recliner levers. Now this only applies to the cloth seats which are mainly the LS models.
From what I know, parts for Blazers / Jimmy's are plentiful in the States. So why don't you guys do what I did!
Go to the junkyards & get a set of leather seats from the LT. That way, not only do you solve the problem going forward but you gain leather trim & electric seats. All "plug & play"
I fitted the door panels from the LT as well.
my metal shaft it attaches to broke too. i am trying to decide against the $20 with shipping for the pair off ebay or the $30 per lever at another site, not sure if there is a quality difference.
