RPMs drop
Old Mar 29, 2025 | 12:27 PM
TR860's Avatar
TR860 will become famous soon enough
Default RPMs drop
Hi everyone, been awhile since i have been here. So my problem is when i am sitting idling at a red light or in a parking lot, my RPMs run steady at 500, then all of a sudden rpms will drop to about a 100 like it is going to stall then it jumps right back up. Any suggestions would be appreciated.....98 LST, 4.3L, 4WD....fuel pump was replaced 4 years ago
Old Mar 31, 2025 | 08:01 AM
Stovey's Avatar
Stovey will become famous soon enough
I had the same problem, and in my case it was the brake booster.
If the brake pedal is sinking to the floor as idle drops, then the brake booster or brake booster valve could be faulty.
Old Mar 31, 2025 | 09:54 AM
TR860's Avatar
Thanks, i never noticed if it does will pay more attention to it,
Old Apr 5, 2025 | 10:52 AM
daveca's Avatar
First guess, ignition module. They cut out at idle/ low speeds a few times then leave you stranded in an intersection!
Connect a timing light to the coil wire, tape the light to the hood so you can see the flashing while driving. The light will become erratic if the ignition cuts out.
Old Apr 6, 2025 | 12:56 PM
TR860's Avatar
Thanks, going to switch this out and hope it works, it is probably 27 years old, dont have access to a timing light
Old Apr 7, 2025 | 05:35 PM
TR860's Avatar
After looking at this dont look like a big project, probably going to change coil pack too...Thanks
Old Apr 10, 2025 | 12:07 PM
TR860's Avatar
okay so changing these didnt help. My next question is there a easier way to change the IAC valve without having to take the throttle body apart
JessenU
Jan 20, 2023 09:50 PM
Lgarretto
Lowering Tech
Oct 25, 2021 08:28 AM
Old Skool Soldier
Apr 18, 2012 10:07 PM
blazin97
Suspension Tech
Dec 13, 2004 12:06 AM
