Saggin?
Old Oct 14, 2009 | 01:13 AM
wlorton's Avatar
I understand that... but I was hoping to slowly work the lifts... like to be honest... 2-3in body lift... 6in superlift.... and possibly throwing some blocks on the back... and maybe extra tbar cranks... but the tbar crank is kinda the last ditch effort... I was hoping to see up to 9-12in of lift...
Old Oct 14, 2009 | 01:17 AM
okvortec's Avatar
3" BL, 6" SL, 1.5" torison...10.5" ??
Old Oct 14, 2009 | 01:19 AM
wlorton's Avatar
2in body lift...
6in suspension lift...
3-5in blocks between suspension and frame.... saw a few kits... need to find them again...
thats 13in lift....
Old Oct 14, 2009 | 01:24 AM
okvortec's Avatar
That'd be cool, but I have one question. If you put 3-5" of blocks with the 6"SL, would you need shocks from a 9-11" kit?
Old Oct 14, 2009 | 06:41 AM
oktain's Avatar
Hang on, what blocks are you refering to? Sounds like you'll be needing to flip the differential to the lower side of the leaf springs, and I'm pretty sure complications can arise from this. I'd get Kyle's input on on this matter. Usually blocks are used to lower a truck.
Old Oct 14, 2009 | 07:18 AM
Originally Posted by stsrus
Are you sure that you're not going through a growth spurt?
My first thought!
Blocks in the suspension should be a last resort kind of lift. Given the stock axle over spring configuration, blocks would serve to lower your truck. If you do a SOA (spring over axle) flip, you will be lifting it by ~4" right off the bat and then need to find a way to get the front up. The 5-6" kits available do a SOA with an additional 1-2" in the rear springs while providing the drop brackets for the front diff and suspension.
If it were me and I was worried that the springs were sagging in the rear, I would remove them and have them re-arched. It is not an expensive proposition and you'll likely be able to find a local spring shop that is capable of doing the work. It will not provide a ton of lift so if that is what you are after, then this is not the complete answer...
Is this thread about sagging and how to fix it back to stock or about lifting??
Old Oct 14, 2009 | 09:09 AM
wlorton's Avatar
It was about sagging and then slowly morphed to the lift....
Old Oct 14, 2009 | 11:01 AM
blazer_grl's Avatar
blazer_grl is on a distinguished road
I couldn't help myself from being a smart ***...
But would this help?
* at pic*
Since when did Fredrick's of Hollywood start makin' car bras? =P
jbb421
Suspension Tech
Aug 1, 2012 06:24 AM
all4x492
Sep 22, 2006 09:11 AM
