shimming rear diff..needed??
Old Dec 23, 2009 | 08:15 PM
Buschkj24's Avatar
Buschkj24 is on a distinguished road
Exclamation shimming rear diff..needed??
i am going to be replacing my g80 with another g80 that my father in laws brother has at the shop. my question is, once i remove the whole rear differential do i need to shim the diff when i install the new assembly? i would be using the same pinion and ring gear. if i need to shim the diff, how do i go about doing that, is there a good write up that i can read up on? thanks
Old Dec 23, 2009 | 08:23 PM
You will have to redo the shims side to side due to manufacturing tolerances on the differential housing. You won't have to redo anything on the pinion though unless you are replacing bearings and even then, you could likely use the same setting.
You should be able to turn up some pretty good articles online.
Old Dec 23, 2009 | 08:58 PM
Buschkj24's Avatar
i was almost thinking of just replacing the broken parts that is in there now, but i do not know what size g80 he has, do they all use the same parts or with the different size's use different size gears on the sliding plate?
ShawnS89
Jun 21, 2014 11:03 PM
babeba67
Jul 9, 2012 03:18 PM
CJB
Feb 9, 2011 08:20 AM
zoni
Jan 16, 2006 04:49 PM
