shotgun fix
Old Apr 18, 2023 | 02:11 PM
badChevyvortec99's Avatar
badChevyvortec99 is on a distinguished road
Unhappy shotgun fix
Hello, I have a 1999 Blazer 4.3 2 wheel 2 door. I had problems with it jerking while shifting to 3rd gear. If I got into it I wouldn't have any problems.
Now it died. replaced the distributor cranks but no fire. I am thinking electrical, I saw in this forum that maybe instrument cluster.... Also coil pack?
Running out of money and ready to dump it. low miles and strong motor. The weird thing is my temperature guage needle is stuck downwards.
This vehicle had been sitting and had mice. Any ideas I would appreciate it.
Old Apr 18, 2023 | 07:54 PM
GeorgeLG's Avatar
Is there spark output from the coil before the distr?
George
Old Apr 18, 2023 | 08:41 PM
I have power showing from the coil to the distributor when ignition is on. going to do a bench test on the coil pack.
Old Apr 18, 2023 | 08:59 PM
GeorgeLG's Avatar
If you pull the high voltage lead off of the distr but leave the other end connected to the coil and create a 1" air gap to ground do you get a strong regular spark when you crank the engine?
George
Old Apr 19, 2023 | 11:20 AM
I will check, I have a cheap tester that wouldnt produce any spark before I had the new distributor put in.
Old Apr 19, 2023 | 10:32 PM
I checked and there is no power to the distributor. would that be the coil pack?
Old Apr 19, 2023 | 10:35 PM
GeorgeLG's Avatar
So there was no high voltage spark from the coil lead during cranking?
George
Old Apr 20, 2023 | 09:20 AM
nothing, I used both a cheaper spark tester and my 12 volt tester and had not power or spark.
Old Apr 20, 2023 | 09:24 AM
GeorgeLG's Avatar
Where did you test and not find power?
George
Old Apr 20, 2023 | 12:09 PM
I tested both the spark plug lead from the distributor #1 and the coil wire going to the distributor.
