Spare tire confusion
Old Sep 2, 2019 | 07:42 PM
odat's Avatar
Originally Posted by Small Arms Collector
Hmm, says that is 15 inch though.
Also, you see what I mean about price, seems high for what it is.
What you are measuring is not tire or rim size just across the outer rim diameter - for tire size it's across the center hole of the tire from bead to bead - so your rim's are 15" and $150.00 and up is about normal cost for a new rim
Old Sep 2, 2019 | 09:08 PM
odat's Avatar
The tires, FYI, are 235/75R15s, I believe that’s slightly larger than factory if I’m remembering right, would those fit the spare tire carrier? I just noticed when taking the pictures earlier that the remaining old ones are 4 years old and have some dry rot, though the treads visually look about as deep as the new ones, should I replace those, or do you think the tire shop was right and they may still work?
The door tags on the three 4X4blazers I've owned all stated 235/75r/15 and that's what size of tires they had on.
Two of them had the spare mounted inside - drivers side and were donuts, third had a external rear mount and was full size
Depending on where the dry rot is and how deep, the sidewalls in the two pictures you posted I don't see any thing to be concerned about ....
Old Sep 2, 2019 | 09:44 PM
Small Arms Collector's Avatar
Small Arms Collector is on a distinguished road
The top picture was one of the new ones, only about 500 miles on it, the second one is one of the older ones, I’ll try to get pictures of the dry rot tomorrow.
I thought the factory size was 235/70R15?
Old Sep 2, 2019 | 09:48 PM
I just now happened to have my decoded RPO codes and mine came with a full-sized spare.
Old Sep 2, 2019 | 10:02 PM
odat's Avatar
All three of mine were 1st Gens so that may be the difference
Old Sep 2, 2019 | 10:51 PM
I should have been more explicit; my 1999 came with a full-sized P235/70R15 stowed under the back bumper on a steel rim.
Old Sep 3, 2019 | 04:10 PM
This is what I have. Looks pretty close to me (except for color, of course).
Old Sep 3, 2019 | 05:16 PM
Check your messages. That looks beautiful and I think exactly what I have (sans my ugly paint).
Old Sep 3, 2019 | 05:46 PM
You've got mail!
Old Sep 7, 2019 | 04:20 PM
Here is a picture of that dry rot I mentioned.
