Spot Lights in Front of Grille
Hi all,
I have a 2002 GMC Jimmy. I would like to install some small square 3" spot lights in front of my grille, much like this:
How would I attach my own to a similar effect as above? The grille is all plastic. I suppose I would have to make some brackets that connect elsewhere for structural support and reach down to the base of the grille.
How have others done this? Help me brainstorm.
Thanks!
Thanks!
I think the easiest way would be to drill holes in the bumper and just run a bolt through it. Unless you're trying to keep from doing that, then I guess you could go through the trouble of making your own bracket. Also, have you thought about using LED's? I'm personally in love with them since they use a lot less power and give equal to or more light than regular off road lights. Plus, I have never had to touch a relay since the LED's draw so little power.
Drumer73
Mar 1, 2009 06:19 PM
