Spot Lights in Front of Grille
Old Feb 11, 2015 | 02:32 PM
ZEALER's Avatar
ZEALER is on a distinguished road
Default Spot Lights in Front of Grille
Hi all,
I have a 2002 GMC Jimmy. I would like to install some small square 3" spot lights in front of my grille, much like this:
How would I attach my own to a similar effect as above? The grille is all plastic. I suppose I would have to make some brackets that connect elsewhere for structural support and reach down to the base of the grille.
How have others done this? Help me brainstorm.
Thanks!
Old Feb 11, 2015 | 02:55 PM
lazyboyjake's Avatar
lazyboyjake is on a distinguished road
I think the easiest way would be to drill holes in the bumper and just run a bolt through it. Unless you're trying to keep from doing that, then I guess you could go through the trouble of making your own bracket. Also, have you thought about using LED's? I'm personally in love with them since they use a lot less power and give equal to or more light than regular off road lights. Plus, I have never had to touch a relay since the LED's draw so little power.
Old Feb 11, 2015 | 03:56 PM
ZEALER's Avatar
Ya the lights I have in mind are in fact LED's.
Won't drilling through the plastic bumper cover still be too flimsy? That is my main concern with that idea.
Old Feb 11, 2015 | 06:06 PM
What kind of road/trails are you going to be using this on? If it's not bumpy to the point where things on the inside are shaking then you should be fine.
Old Feb 11, 2015 | 08:53 PM
TMR_BLAZER's Avatar
TMR_BLAZER is on a distinguished road
I would just fab up a little "L" shaped bracket and go behind the grill and down to the core support or metal bumper
Steve-o
Feb 26, 2014 04:27 PM
Drumer73
Mar 1, 2009 06:19 PM
Indo G
Jul 4, 2008 07:51 PM
bufferpad
Feb 26, 2005 12:15 PM
