starting issues! need advice
Old Jan 7, 2011 | 01:28 PM
Ape357's Avatar
Ape357 is on a distinguished road
Default starting issues! need advice
i have a '96 blazer 4x4 4.3L and i'm having issues with starting. i recently did a tune up (plugs, wires, new distributor assembly, egr valve, all vac. lines, etc.) the starter is ok but i have to cycle the key at least three or more times (sometimes less) in order to crank. when it doesnt start right away i hear the starter motor spin but doesn't fully engage flywheel it seems. when i cycle the key i usually remove then re-insert key adn it will turn over. I'm wondering if the issue is either ignition switch or if i need to shim the starter. any advice on this issue would be helpful! thanks
dieseltwitch
May 24, 2013 04:43 PM
Ape357
Jan 8, 2011 07:53 PM
cgrett
Nov 15, 2010 09:08 PM
rcravincase
Sep 13, 2009 07:58 PM
Sprocket
Mar 20, 2008 09:39 PM
