Stock Front & Rear posi???
Old Dec 6, 2008 | 10:01 AM
02BlazerS.jersey's Avatar
02BlazerS.jersey is an unknown quantity at this point
Default Stock Front & Rear posi???
Hi I have a 2002 blazer 4wd Whenever i punch it both rear tires engage... also when in 4wd all 4 tires always grip. Did GM make sum blazers with stock front and rear posi or limited slips??? My friend has a 96 blazer and his don't lock up both or all 4 like mine, I was thinking maybe sum kind of option that original owner got with it?? Any sugestions?? Thanks!!!!
Old Dec 6, 2008 | 10:11 AM
AJBert's Avatar
Default RE: Stock Front & Rear posi???
Do a quick search for G80, that'll tell you how to find out what you've got in the rear. No type of factory locker or LSD up front, though.
Old Dec 7, 2008 | 12:04 PM
WolfPack's Avatar
Do you have AutoTrac 4wd?
Old Dec 7, 2008 | 12:13 PM
Don't know heard of AutoTrac from someone before. How would I know ?? Can I bring it up by my Vin# to see what I have somewhere??
Old Dec 7, 2008 | 12:18 PM
WolfPack's Avatar
You would have the Auto 4wd option on your 4wd switch. Non-autotrac blazers got 2Hi, 4Hi, 4Lo.
Old Dec 7, 2008 | 12:35 PM
Yeah, guess not just got 2hi, 4hi, 4lo options. Thanks!!
Old Dec 7, 2008 | 03:22 PM
The front differential is a standard open diff. There is no locker or even a limited slip made for these as the aluminum housing is not all that strong and it takes a ton of work to get to the diff (ie. removing the whole front axle assembly and splitting it in half).
The Gov-Loc (RPO code G80) differential was an optional rear diff. It acts as a standard open differential at speeds above ~30MPH, but has a governor inside that locks the wheels together if it senses an RPM differnce of 100-200RPM (IIRC) between the left and right wheels (below 30MPH as mentioned earlier). This diff has its limitations and inherent weaknesses, but for normal on-road conditions, it is a good compromise between an all out locker and an open diff.
Old Dec 7, 2008 | 03:29 PM
Thanks!!
ckroll98
Apr 16, 2014 05:38 PM
ckroll98
Aug 30, 2013 07:53 AM
blazer1992
Jul 9, 2011 10:34 PM
chris015
May 27, 2009 11:10 AM
stensg
Apr 19, 2009 06:29 PM
