Stupid winter
It's getting colder in the mornings and at night. Decided tonight to start replacing the heater core in my jimmy. Need to buy a replacement tomorrow and fnish that portion of it. At the same time I am removing the A/C. I have half the old heater box off, but now I need to remove the inner fender to get to the last bolt .[:@] It was so much easier changing the heater box out on my blazer when the engine was out.
http://www.blazinjason.com/heatercore1.jpg |
RE: Stupid winter
good luck, i had to have mine replaced last winter, the WHOLE dash had to come out and it wasnt cheap for all that
RE: Stupid winter
w00t I finally have heat! Took me a little longer than I had planned. Since I had the wheel well out I decided to take out both and powder coat em. Will get some pics later.
RE: Stupid winter
Congrats on the successful repair!
RE: Stupid winter
The actual changing of the heater core is quite simple and straight forward. Much easier than on my old thunderbird was. http://sytyarchives.com/howto/viewar...imate_controls Is a good read and will help. I also removed the A/C system. Here is what an A/C heater box looks like and what I started with.
http://www.blazinjason.com/heaterbox2.jpg Here are heater cores. The one with the longer tubes for A/C and the shorter for no A/C. I bought both just in case I couldn't use the non A/C core. The cores are pretty much the same with the only exeptition being the tubes from what I could see. Although the tubes on the non A/C core could be a little longer. I think in the long run that there might be less chance of the tubes leaking since they are shorter. http://www.blazinjason.com/heaterbox1.jpg Here is a heater box from a non A/C truck after being powder coated gloss black. The wheel well has to come out in order to remove the old box as there are a couple bolts that you can't get otherwise. Luckily I only had to cut off 1 body bolt while removing the inner fender. http://www.blazinjason.com/heaterbox3.jpg I also put in an A/C delete pulley that I picked up from summit. It was much cheaper than LMC. I also powder coated the wheel wells since I was at it. No pics, but they are much nicer and shouldn't rsut anytime soon. Still need to re wire loom some things etc. |
