Stupid winter
Old Sep 19, 2007 | 11:22 PM
Blazin_Jason's Avatar
Default Stupid winter
It's getting colder in the mornings and at night. Decided tonight to start replacing the heater core in my jimmy. Need to buy a replacement tomorrow and fnish that portion of it. At the same time I am removing the A/C. I have half the old heater box off, but now I need to remove the inner fender to get to the last bolt .[:@] It was so much easier changing the heater box out on my blazer when the engine was out.
Old Sep 20, 2007 | 04:36 PM
blznlowxtreme's Avatar
blznlowxtreme is an unknown quantity at this point
Default RE: Stupid winter
good luck, i had to have mine replaced last winter, the WHOLE dash had to come out and it wasnt cheap for all that
Old Sep 23, 2007 | 11:42 PM
w00t I finally have heat! Took me a little longer than I had planned. Since I had the wheel well out I decided to take out both and powder coat em. Will get some pics later.
Old Sep 24, 2007 | 06:18 AM
Congrats on the successful repair!
Old Sep 24, 2007 | 08:16 PM
The actual changing of the heater core is quite simple and straight forward. Much easier than on my old thunderbird was. http://sytyarchives.com/howto/viewar...imate_controls Is a good read and will help. I also removed the A/C system. Here is what an A/C heater box looks like and what I started with.
Here are heater cores. The one with the longer tubes for A/C and the shorter for no A/C. I bought both just in case I couldn't use the non A/C core. The cores are pretty much the same with the only exeptition being the tubes from what I could see. Although the tubes on the non A/C core could be a little longer. I think in the long run that there might be less chance of the tubes leaking since they are shorter.
Here is a heater box from a non A/C truck after being powder coated gloss black. The wheel well has to come out in order to remove the old box as there are a couple bolts that you can't get otherwise. Luckily I only had to cut off 1 body bolt while removing the inner fender.
I also put in an A/C delete pulley that I picked up from summit. It was much cheaper than LMC. I also powder coated the wheel wells since I was at it. No pics, but they are much nicer and shouldn't rsut anytime soon. Still need to re wire loom some things etc.
247monster
Jun 30, 2012 12:20 PM
CraigSnedeker
Jan 26, 2010 01:18 PM
94Jimmy
Dec 16, 2009 06:42 PM
hdlogistics
Tires and Wheels
Mar 31, 2007 01:03 PM
Dodge Guy
Jun 28, 2005 02:04 AM
