-   General Chat (https://blazerforum.com/forum/general-chat-34/)
-   -   Things I need/want and things I'm doing to the blazers (https://blazerforum.com/forum/general-chat-34/things-i-need-want-things-im-doing-blazers-51456/)
travisrussell88 Nov 11, 2010 08:21 PM
things I need to get or to do...
'92 s10 blazer
-heater core -need to put it in
-heater hoses - need
-center console - need red for standard
-weatherstripping - need
-window track - need
-cowl hood - want
-washer fluid reservoir - need
-dash- want red
-tachometer - want
-spare wheel/tire - need 15" wheel
-spare tire equipment - need
-center caps - need
-tires - 2 on order, need 2 more
-2 lug studs/nuts - need, need to get backed out and crossthreaded studs/nuts off
-springs - want as mine are worn out
-shocks -want as mine are wearing
-bowtie for grill and badges for body - want
-late model 15" factory alloy "swirly" wheels - want
'98 blazer 4 door
-center console - want
-dash bezel - need
-battery - need
-battery bolts - need
-radio - want
-rear bumper - want (mines dented)
-inspection - need
-muffler - want as mine is worn out
-front tires - need
DKSDAD Nov 11, 2010 08:29 PM
Good luck with everything!
84BlazerS10 Nov 11, 2010 10:21 PM
Good luck sounds like you have quite a job ahead of you.
travisrussell88 Nov 25, 2010 11:18 AM
1 Attachment(s)
Okay, so me and my girlfriend replaced the oil pressure switch because it started leaking bad and also pulled the driveshaft out and replaced the u-joints front and back, now that was not easy on a lowered truck, lol
travisrussell88 Dec 30, 2010 11:53 AM
Radio is done .The old heater core is out, the new one is in, gotta put the dash back together, hook up the hoses and thats done, maybe I can add the tach today, straightened the door, fixed the taillight, still gotta fix the tstat housing, and bleed the brakes (once I get that damn crossthreaded lug off of the backed out stud) and figure out my brake problem (lost brakes christmas eve) when peddle is pressed the booster makes a shhh sound which I never noticed before...anyway its back to work
travisrussell88 Apr 7, 2011 09:52 PM
So, brakes are done it was the right rear wheel cylinder that was bad, tach is in as of today, new clutch master and slave cylinders, got center caps, bowtie for grille, spare wheel and equipment, and various small interior trim pieces
Benedict1337 Apr 7, 2011 10:21 PM
heater cores suck to replace, thats cool your gf actually helps you fix stuff, mine just pokes me with the screw gun asking me if I'm done yet haha
travisrussell88 Apr 7, 2011 10:26 PM
Except she bitched about it and everything else, and was a nutjob, so she had to go...she was actually jealous of the truck which is why I didn't get much done with her in the picture...If i wasn't with her I had better be at work, couldn't even do homework, but now she's gone and I'm back in school, and getting alot more done on my truck and I must say even though I'm not getting laid every night I'm happier.
Benedict1337 Apr 7, 2011 10:35 PM
lol my girlfriend thinks my truck is a death trap and she usually doesn't want to be around when I'm working on the truck, luckily my friends like to help me work on the truck goes a lot faster when they are around. I have a tendency to misplace tools and pieces haha. I get more done when I'm off of school but there is always the temptation to skip class and work on my truck if its nice out
travisrussell88 May 7, 2011 10:51 AM
Front suspension is all stock now with new moog springs, balljoints and bushings. blocks gone from rear.
