Transmission issues
Old May 12, 2021 | 09:35 AM
Archer2021's Avatar
Archer2021 is on a distinguished road
Default Transmission issues
OK so here’s the deal I just picked up a 1998 blazer from my uncle that has a monster transmission 4L 60 E and a 1650 RPM stall torque converter. Has very low mileage on everything due to a rebuild a year ago. I drove the vehicle from OKC to Wichita never missed a beat two weeks following the return of the vehicle I started having issues with it slipping from second gear to third gear I would have to let off the throttle for it to shift into third and then I can get back into it. the problem got worse to wear even at low RPMs second gear would start to slip right around 3000 RPMs. It got so bad two weeks ago that I had no first second or third when trying to manually shift and while in drive I had to be very light on the throttle just to get it to go anywhere otherwise it would slip now my question is do I have something internally wrong with it Could it be a torque converter issue or could it be shift solenoid’s I’m at a loss in about a tear it apart I’m just looking for some insight thank you for your time
Old May 21, 2021 | 12:10 AM
Theblazomatic2's Avatar
Theblazomatic2 is on a distinguished road
if the 3rd gear started slipping first then you probably burnt all the clutches. Might as well replace or strip it down and rebuild it. Do it right so you don’t have to do it again.
Old May 22, 2021 | 07:04 PM
Archer2021's Avatar
Awesome thank you for the response. Yeah I believe that is the smartest idea at this point too. Just can’t figure out why a monster transmission with 25k on it would burn out so easy. Oh well i suppose.
Old May 23, 2021 | 12:59 AM
Mods's Avatar
I've heard some, really horrible things about Monster transmissions, so honestly that does not surprise me as much..
Old May 23, 2021 | 05:40 PM
I mean it could of had low fluid or the pump wasn’t pumping enough. Or stuck valve. There’s a lot of stupid simple things I found that can just completely trash your trans
im rebuilding mine right now. My pump actually shattered.
Old May 24, 2021 | 10:25 AM
Archer2021's Avatar
So with that being said I’m under the assumption that in order to rebuild the monster transmission I’ll have to rebuild with their monster kit. Would you or anyone else agree? Cause I know there are master rebuild kits for 200-300$ but the monster rebuild kit is 700$
Old May 24, 2021 | 02:28 PM
I’m not entirely sure about that. Perhaps it depends on what actually needs replaced.
example: if the frictions are the only thing bad I don’t see why you’d need a whole rebuild kit. Just clutches and gaskets etc.
strip it and label everything in bags as you go. Assess all your parts and figure out what you need. Then you can determine what you need and what kit to get.
if you can get the valve body tested for vacuum too I would get it done.
Old May 24, 2021 | 02:31 PM
Archer2021's Avatar
Alright sounds like a plan to me. Thanks so much for the input. Tear down begins now.
Old May 25, 2021 | 01:58 AM
good luck. Mines tor down already. Now I need to just spend the money on new parts🤣.
remember this. If it gets overwhelming just do it in sections. If your pump is damaged just replace it don’t rebuild it.
then you have your valve body, and drum. It becomes easier when you do it that way.
Old May 25, 2021 | 08:29 AM
Archer2021's Avatar
Roger that man. Now I know how to tell if the pump is bad while the tranny is in the vehicle. ( checking the fluid level while vehicle off then checking while running) but can you check while out of vehicle or I’ll know once it’s back in The vehicle hahah lol
Jakester1835
Apr 17, 2017 02:59 PM
Jimmy_Blazer
Mar 24, 2015 11:24 AM
MickeyJ
Oct 17, 2012 12:39 AM
wots_blazin
Mar 1, 2011 07:34 PM
neurotox
Dec 20, 2009 09:43 PM
