Transmission not shifting
Old Mar 6, 2016 | 07:49 PM
mike9812121298's Avatar
mike9812121298 is on a distinguished road
Default Transmission not shifting
So i just changed out the sunshell inside the trans, and i got everything back together and i noticed the green and purple/white wire next to the main plug in the trans is unplugged. when i took it for a test drive the trans didnt want to shift out of gear. where does this go? any ideas will help out a lot thanks.
Old Mar 7, 2016 | 12:27 PM
http://lt1swap.com/HARNES_LABELS_02.jpg
the sensor closest to the main transmission hook up labled speed sensor is the one i have extra
Old Mar 7, 2016 | 01:30 PM
odat's Avatar
bet your speedometer didn't work either - if its what i think it is - 2wd speed sensor on the tail shaft of transmission - 4wd its back on the top of the transfer case - vehicle information would be nice - guessing game from he** without
Old Mar 7, 2016 | 01:47 PM
Sorry about that, its a 2000 jimmy auto 4wd, i found the 2 vss in the back of the diff. but that one that comes off next to the main plug into the trans, does that go over the top of the trans to a plug in by the shift cable?
Old Mar 7, 2016 | 02:33 PM
Attached Thumbnails Transmission not shifting-811bed03-34f0-43f2-9ac1-4d177f22d830_zps3ihg5hqb.jpg   Transmission not shifting-0922c240-2c5d-4b96-a584-8a9e9395400b_zpsdcrlm5o7.jpg
Old Mar 7, 2016 | 09:27 PM
There will be two sensors on the output housing of the transfer case. You are looking for the sensor with the light green w/ black tracer & purple w/ white tracer wires going into it.
The sensor should be a screw in type sensor with an o-ring seal, not the bolt on type. The part description should state that it is for the RPO code NP8 (NV236) or NP4 (NV136) transfer case, but a lot of parts stores have gone dumb with their descriptions.
If you need to, take the sensor with you so the counter person can match it up appropriately.
i took this quote from another post. that's the sensor im talking about i just cant seem to find where it plugs in at
Old Mar 9, 2016 | 07:26 PM
got it figured out it plugged in to the green and purple wire with the adapter on it
SLiMCHeF613
Sep 29, 2014 11:04 PM
jswantek
Jan 23, 2012 09:02 AM
Txguy
Sep 6, 2010 04:52 PM
hmdmom2
Dec 6, 2007 09:25 PM
96jimmy4x4in
Oct 7, 2007 09:23 PM
